need help
Shoemjay
sc
After completing a full 60k(except water pump) my 1991 plus started right up. It idled shi^y and ran decent, but the Idle would fluctuate when in neutral while driving.
So I orded a IAC, installed and started and followed the Idle reset process but still Idle ruff. I let sit for a week and when i went to start CLICK CLICK. Brand new battery. So i went to replace the starter and relized that the POS/Neg where corrided. I figured cool, now got a reason for battery relocation kit for the SOURCE. I read all i could about the install and wiring.
Now she wont start? radio wont turn on , no fuel pump prime noise or pressure(tested). But it will turn over.
I ran the POS+ from batt/solenoid NEG- from batt/to chass(seat belt), the NEG- solenoid/ to the starter.
small ground for the comp to batt, the small flat ground/strap from firewall to the engine w/ new 2g wire. also for good measures i ran a 2g wire from the rear engine intake mount bracket(where the firewall ground goes) to the batt.
All lights work for doors and dash lights and climate. PLEASE HELP this so simple every little thing for the SHO turns to a PROJECT.
