Kagi
My car has been running rich and performing very badly. I have done a tune up and gutted the cats. I still cant figure this out though. I was able to do the KOEO test but not the KOER test. The KOEO test gave me these codes:
111 System checks OK
Then it showed the ones stored in memory
172 (R,M) Oxygen sensor not switching - system is or was lean - Single, Right orr Rear HO2S - Fuel control
173 (R,M) Oxygen sensor not switching - system is or was rich - Single, Right orr Rear HO2S - Fuel control
176 (M) Oxygen sensor not switching - system is or was lean Left or Front HO22SSS - Fuel control
217 (M) Primary circuit failure - ignition coil 3 - Ignition Systems
332 (R,M) EGR did not open/respond during test or if memory code, did not open intermittantly - EVR or PFE
542 (O,M) Fuel pump open, bad ground or always on - - Power / Fuel Pump Circuits
543 (O) Fuel pump monitor circuit shows no power - Power / Fuel Pump Circuits
(M) (Service 556 code first if present) Fuel pump relay or battery power feed was open - Power / Fuel Pump Circuits
With these where should I start first?
Also I'm not sure if I am not doing the KOER test properly. I start the car and see the CEL blink three times and then the rpms go up so i turn it a half turn to the right and then to the left. I then hit the brake and then turn off overdrive and then back on. After that nothing happens it stays rev'd up.
