RedDemonSHO
ok i bought a 93 ATX that some one started swapping to a MTX ok the stuff that was done swapped MTX sub frame, bizzy trans, new clutch and new flywheel, new clutch cable, jose short shifter, trans mount and pedals. ok now the bad still has ATX motor mounts and have no idea what they did with the wiring but it runs drives nice starts fine idles normal ON START up no 4k rev limiter, no lights on dash. the problem im having is that after you push in the clutch at a stop sign or anything it revs to 2200 rpms and stays there tell you shut it off and restart it and seems to smell rich after driving it.:banghd: it is running the ATX computer. if any one can help that it would be much thanks. if you need any other questions please ask!!
