Henderson Stephen
Looking for parts source for sho parts, really need strut rod pass.
Thanks
Thanks
Start underneath the radiator and ends up at the bottom lower control arm.You talking about the one that runs sorta parallel to the body under the rocker panels?
Unfortunately, none of the above. My after hours mechanic beside a 3-foot breaker bar And small torch would do the job. He definitely need a bigger torch because he snapped the threads right off the thing. He has a bad habit of breaking parts that are one of a kind and hard to find.Is the rod broken/corroded through or is it loose?
