Need Help Fast
Status
Not open for further replies.
SHOMADMAX
Speed Demond!
WA, I miss WY!!!
no it is not low on antifreeze but for some freakin reason there is no fluid going through that top hose of the radiator into the themostat...WTF
N3FOL
Pennsylvania
I had a similar situation when I replaced my wife's minivan rubber hoses and thermostat + water pump, etc... What I did is that I took off the radiator cap and started the engine. I slowly topped off the radiator with antifreeze as the engine temperature rises. I suspect that there is air in your system. So if this is true, be patient and purge that air out slowly. Good Luck.
Status
