I just got my Rotunda teves Ford bleeder in the mail. I did the procedure right, and it worked as it should. I then proceeded to bleed the rear wheels rr,lf,lr,rf. I had someone in the car with it off to assist.
Needless to say if I step on the brakes as hard as I can I can't stop. If I push the brakes at like 70 the pedal will go to the floor and it is scary. Then you just smell the front brakes burning. It's pretty bad, I can't believe I drove my first sho with this problem for a long time and i'm alive to talk about it.
I just bought the car, if I can't get good brakes I will sell it. I also noticed that the person used compression fittings under the hood for the lines. I know that I have to get rid of them, but do I have to get a bubble flare kit? I was so damn excited to get the bleeder in the mail and I still have bad braking. Luckily I have another car to drive, I haven't even put the sho on the road yet i'm driving around with a temporary tag.
I also have a phoenix injector but I didn't use that.
There are no leaks, and the rear calipers are working, the rotors get hot, and I had fluid flow. I was planning on getting bias plugs, but that's after I get good brakes.
I really need any suggestions. I'm already very disappointed that I bought this sho, it needs more work then I thought. thank you
