Need help asap
EcoBoostSHO
Minnesota
Try reading the codes with the tuner. Write them down and then search or post them here...that would be a good first step. Have you tried going back to stock with the 2bar?
^x2. Pics of the MAP installed on top of the manifold please. Rarely, an incorrect tune can get sent to you. You can have LME check & resend, just in case.
AndrewGanoe32
2013 sho
The car throws 3 codes total. I will write them down and post on here. And yes I'm sure that it is 3 bar map sensor tune because it says it on the tune and something is definitely wrong because when the tune is loaded and put the car in sport mode it jumps up to 25 mph without even moving
yo tony
Manning, SC
We're you sent any other tunes like a 91 octane or 87 octane? Check the part number on the map sensor, I remember reading on here that someone got the f 150 version, then I would blow up Livernoise phone until that crap was fixed. Torrie could have u a tune within an hour if it came down to that as long as your tuner is compatible
AndrewGanoe32
2013 sho
They sent me a 91 octane 3 bar map sensor and a 93 octane 3 bar map sensor tune. It throws all the codes with the 91 octane 3 bar map sensor. Haven't tried the 93 octane tune yet scared too. I will double check the part number on the map bar sensor but I'm pretty sure that's it is a 3 bar map sensor and don't worry I plan calling them today and getting the problem fixed today
AndrewGanoe32
2013 sho
That's the map sensor that I bought for the car.
These are the codes that the car is throwing
P0106
P2196
P2198
U0401
Livernois Motorsports
SHOForumSponsor
Sponsoring Vendor
Dearborn Heights, MI
P0106
P2196
P2198
U0401
I will put money on the fact that you simply placed the 3 BAR in the wrong place @AndrewGanoe32 it happens often.
Did you get the CEL after you loaded the 3 BAR tune? Where did you install the 3 BAR MAP sensor that you purchased? If you installed it near the throttle body that is your problem.
EcoBoostSHO
Minnesota
P0106 is for the MAP sensor...Also the symptoms are very similar to what happens when you have a 2 bar map sensor installed or it's in the wrong place. I'd bet that is your problem or somehow your new sensor is already bad. Make sure you replaced the one ON TOP of the manifold. It's circled in RED on the PIC.3bar map
13blacksho
Des Moines IA
This sound very frustrating, this is one of the reasons I went with Unleashed, you have the ability to datalog with the SCT tuner. It is not an option with the Mycal.
What wont show up on the dash? "Sport mode" or the check engine/maint lights?
And Torrie will send a new tune in an average 53 seconds:biggrin:
I want to take the the time to thank everyone for helping me out with the car everyone as right the map sensor was place in the wrong place did everything livernois told me to do. And now the car is running really well.
Now you will have to do whatever Jaimie wants! I do dread debt collection time :D
BigB15
GA
Torrie has been suspected to be directly wired into the interwebz via his nervous system!!!
Rich
I will never complain about customer service of that level.
You usually have to pay for an expensive contract to get that level of support.
yo tony
Manning, SC
Torrie's company has honestly been the best company I've ever dealt with online.
