need help asap
newshofan
chattanooga, TN
ok so ive checked every where for the best and cheapest parts. either sho source or rock auto but i am confused between some things would it be possible for some one to email me the proper checkout.....i need the valve cover gasket plus the gromet covers i dont know if the valve cover gasket comes with them. also i would like either double platnumm or iridium plugs the better ones at cheaper. on sho source i think they are seperate. would assume it is best to have them especially since i dont think the 60k has been done before also i need the shims for vavle ajdusment im not doing the maint as i am not a mechanic. having ford or other do this someone please help 95 3.2atx thank you very much i would appreciate all the help i can get email is [email protected] or [email protected].....
Edit/Delete Message
jmpSHO
Massachusetts
SHO Source is the only place that sells the valve cover grommets. As for valve cover gaskets you will just have to shop around for the best price. I am almost positve that all valve cover gasket sets come with the plug well seals, you will most definately need those too.
