Need bolts to remove crank sprocket
DemonNeno
SHOCAGO Freak
Skokie, IL
I can't seem to find any sources for these. I found the right size and pitch (m5x.80) but can't seem to get a hold of the length needed. Any ideas? Chicagoland area? My one source that I've stuck to all along is now closed (uptown des plaines).
K-Dawg
Treasure Coast, FL
MTX cars have two.
After going to every hardware store I could think of, I finally found one that was long enough. And they only had one.
DemonNeno
SHOCAGO Freak
Skokie, IL
Hah! Go figure.. After spending the whole day looking for them! I dont think the motor that the crank is coming out of has the belt cover bolts anymore, but I'll check to see.
itwonder
VA
One person who posts here just drilled out and re-tapped the holes in the crank pulley to accept easier to find inch-sized bolts.
Exitwound
_McLovin_
Wisconsin
Fastenal. They have any bolt you would ever need. You may have to buy a few of them but you will get what you need.
DemonNeno
SHOCAGO Freak
Skokie, IL
Well, they worked great! Thanks for the tip fellas! Ended up using shorter bolts to complete the removal of the sprocket w/o any inner fender clearance issues whatsoever. :thumb:
