91SHOInterceptor
I have had my SHO for almost 5 years now and work on it alot so this problem has got me. I cant figure out whats wrong with the car overheating. I havent driven it much but I cant seem to determine the cause.
Problem: The car overheats mostly while at idle. It still gets hot while driving and stays near the "R" and "M" when driving. If I let the car sit at idle for awhile, the guage goes all the way to and alittle past the "N". The engine light never comes on. Long drives it stay pretty much in the middle but heats up quickly.
The oil light also flickers while the car is at idle, BUT only when it has been running for quite some time. I drive and it goes away. There are NO oil leaks anywhere. There is plenty of oil. I probably have to replace the oil pump since it wasnt during the rebuild.
I replaced the double core radiator, new reserve coolant tank, new thermostat with gasket, new upper and lower radiator hoses. The water pump is about 2.5 yrs old and looked good during the engine rebuild this winter. I replaced the radiator cap as well. Both temp sensors were replaced also. The fan DOES come on at the default temp.
Other Symptoms: Coolant sometimes leaks out in between the water manifold and the thermostat housing. I took that apart and replaced it with another new gasket. It still leaks at times. The upper radiator hose gets really pressured and you cant hardly squeeze it at all unless you release the pressure from the radiator cap. No other coolant leaks can be found. Heat core works fine. There is coolant flowing through it just fine. There has been no coolant in the oil at all.
I am up for any suggestions. It might be a faulty head gasket but I want to be sure before I start going that route. What other things can point to the faulty head gasket? Any other suggestions to try figure this out?
I have several more parts just waiting to be bolted on to increase its performance but dont want to be tempted to push it until I figure this out. Any thoughts, suggestions would be greatly appreciated. Thanks
