NCSHOracer
Fear The Rasp!
In my 93 MTX with a rebuilt 3.0 we have got about 2500 miles on it where it ran beautifully and with no problems. But not long ago it developed a miss while cruising on the highway that has gotten worse. The car STARTS and IDLES with absolutely no problems and triggers no CEL's. When you get it on the road and strat getting it hot about 15 minutes later it will start to miss slightly and hesitate, when this happens it runs rich and backfires and pops and wants to die. BEFORE the popping occurs the CEL will flash and cut off and you can hear the airbox make sucking noises like it is clogged. Then the bucking of the car occurs and wants to die and stall. The following has been replaced:
- Both O2 sensors
-Cam
-CPS
-TPS
I have checked the codes and the ONLY code to pop up is 519 which is for the power steering pump switch. Will the power steering pump switch cause all of these problems or do I have another problem?
Thanks for reading!
- Both O2 sensors
-Cam
-CPS
-TPS
Thanks for reading!
