38SHO
#1 Oil Abuser
what else the SHO needs:
BBB's
Ported Intake
Underdrive Pulleys
Maybe a different, lighter side exit exhaust
New Transmission, hopefully I'll be getting Kelvin's soon
clutchnet puck style clutch disc
what it has:
3.2 swap... 3.0 cams, one day I'm gonna put on new rings/refurbished 3.0 heads/new headgaskets... if it blows before then I'll just get another 3.2 to freshen up
Borla catback
190lph walbro pump
intake restricter removed
what parts I've started to collect/need to install:
8lb flywheel
ceramic tob
catless y-pipe
lightweight plastic racing seats
whats going on this weekend:
weight reduction.......
-removing rear speakers/sound deadener
-removing JBL amps and wiring
-moving radio to EATC location, run new wiring to front door speakers
this makes way for 2, triple gauge panels for the din slots
-removing dash for a couple weeks to remove wires, modules, airbags, relays, blower, a/c ducting, evaporate/heater core/case, left over metal ac lines
my goal on weight reduction is to keep it around 3000+pounds with decent looking interior, will retain dash, door panels, working windows, center console, and rear seat/carpeting.....
next phase of weight reduction is:
New brake system, convert to a non ABS system, implement an adjustable bias controller and remove the factory one attached to rear control arms. Install 94+ Knuckles, 13" Cobra brakes, 16" lightweight wheels, 205/50/16 rubber for street, install race steering wheel, I've already removed some things from under the hood but I"ll get more frugal... power steering resavoir bracket days are numbered....... things like that will get the scrap pile...
after I'm to this point I will try to weigh the car and check the balance, to determine where the battery should be placed and what type(weight)
I will also be adding some gauges, at the minimum:
-Oil Pressure
-Water temp
-oil temp
-nitrous pressure
-fuel pressure
-wideband o2
yes one day I"ll add a ZEX kit to it and make the last 3 gauges actually worthwhile......
so this is where the 93 SHO is going, hopefully one day I can get another one and take this off the road as its currently my only 4 wheel'd ride......... I don't really want to go Forced Induction and deal with horrible traction and breaking the drivetrain..... so I'll keep it N/A and lighten it to compensate...
I'm gonna start taking some pics of what it all looks like now and work in progress... hopefully I'll be ready to make some shake down passes in a few weeks...... I'll keep stuff updated in this thread as well as update my homepage from my sig picture.......
eventual goals are 13 second pass and trap triple digits... without the juice
the juice would mainly be for street roll racing...
oh yeah, I hope this tird makes it to the convention!
if any of you FSHOC peeps need any parts I remove or want stuff for backup, let me know... you can probably have it for free
I also have a HB EATC I'm trying to sell....
BBB's
Ported Intake
Underdrive Pulleys
what it has:
Borla catback
190lph walbro pump
8lb flywheel
ceramic tob
catless y-pipe
-Oil Pressure
-Water temp
-oil temp
-nitrous pressure
-fuel pressure
-wideband o2
