SHOracer14
Me-0 Diffs-6
I've had the privilege of "borrowing" a cat-less y-pipe off of a friend for track use and got to leave it on the car for about a month. Last night we finally switched our y-pipes back. Here is my personal opinion on the pros and cons of each on a stock SHO.
Stock Y-
Pros- Awsome low-end power
Very Quiet so I am able to hear those secondaries roar
Cons- I still don't understand the 90' Angle off the rear bank (on MTX's) but this probably attributes to the low-end grunt.
Mated with a modified SHO will probably choke some power out of what could be gained.
Seems to choke the motor a bit at high revs.
It's stock so it's quiet and loud exhausts are cool.
Cat-less Y-
Pros- Awsome midrange to high-end grunt.
Adds a nice exhaust note until you really get on it and then there is some annoying rasp even with a larger resonator and turbo mufflers.
Won't choke a modified car which could probably make up for the low-end loss with it's mods.
Cons- Man the loss low-end was like night and day to me. The first time I gunned it with the stocky back on the tires ripped were as with the cat-less it felt like forever to get to 4000 to open up them secondaries.
Made the exhaust loud enough to were I had trouble hearing those secondaries roar to life.
As you can see on a stock SHO a Cat-less vs. a Stock Y end up about dead even. What the Cat-less gains in the high-end it loses in the low and vise versa. A cat-less y is a good first mod for somone to build apon but I can see myself getting a 3.2 swap and many other things before worrying about getting a catless y-pipe. I should have exact numbers in a week or so on if I gain or lose when I go to the track with the stocky back on. Let me know what you guys think. Am I totally off base with some of these assumptions or is this pretty much right?? Without numbers yet I can't prove much. When I first had the catless put on I was like holy sheet look at that tach climb but when I put the stock back on I was like holy geez she sure can get off the line now.
Stock Y-
Cat-less Y-
