My old clutch...pics inside...
SHO-NUF93
Zombie
Jacksonville, FL
This is how I found the TOB...along with a few ball bearings scattered in the bottom of the bellhousing.
Heat spotted like a ****...but I've seen worse
Glazed, but, again, I've seen worse
I count 5 broken fingers, and the rest worn nearly all the way through.
The replacement was a Competition Clutch 4 puck ceramic disk, reinforced PP, SHO Bros. billet steel flywheel and ceramic TOB.
Oh yeah, has anyone ever seen a disc like that with two different sized springs in the hub?
ty91sho
EVRYDAYHUSTLIN'
st.cloud MN
yea i have seen that clutch with the different sized springs. i know that the fenco clutch that i got that DIDNT work(because it was to thick and wouldnt disengage) in my sho had them differnt sized springs. i think its for Different engagements like "hard or soft lanching" to take up the chatter. otherwise i think you could use that TOB if you wanted looks good still, :nut: ahaha wow
SHO-NUF93
Zombie
Jacksonville, FL
Meh, I've heard that said about my clutch choice, but I'm happy with it. It fits my driving style perfectly. Plus when I mod more, I don't want to tear into the car again for alittle while...even though next time I'll be able to do it much quicker. It took me about 10 hours total, so... And truth be told, the 4 puck was actually cheaper by about $40, so why not, I figured. Doesn't hurt to overbuild...
Ahh, here's a question for ya...of all the threads I've read on clutch replacement(though, I didn't watch the video mentioned), I never heard one thing about the little plastic pushpin that slips through a hole in the TOB tab and into the clutch fork, I imagine to hold it in place...?
Also, on first start, with the clutch pedal out, I heard a slight ticking, and if I just barely touched the pedal, it went away. I clicked the quadrant once with a flathead screwdriver, and haven't heard it since...nor had any problems with it at all...60 miles into break-in so far.
Cocoa,Florida
i agree with the overbuild idea if you plan on modding alot.
but man thats a **** of alot of clutch,have you driven it yet?
AntF
SC, CA
Mine will probably look something like that when it comes out. Barely able to get it into 1st, and no reverse without massive grinding. Doesn't slip though, so it's gotta be the fingers. Jeez 4 puck...sounds like you're gonna have an on/off switch of a clutch :) sounds fun though ahahah
SHO-NUF93
Zombie
Jacksonville, FL
It's really not that bad. You can feel it grabbing from a stop. But driving normally, it feels fine. The pedal is easier than it was when I bought the car. I did notice after driving for about a half hour or so, after it got warm, it got really grabby...which is a good thing, as far as I'm concerned.
AREA 91
PA SHO SHOP
Area 91
You do realise that in having a 4 puck means that you will be changing the clutch MUCH sooner than a full faced clutch.
SHO-NUF93
Zombie
Jacksonville, FL
That never really crossed my mind. I guess, depending on how much more modding I've done, maybe I'll opt for the fullsize next time.
SHO-NUF93
Zombie
Jacksonville, FL
Damn, just noticed bearing noise in the transmission while engaging the clutch, especially in reverse...guess I never heard it before because of the damn TOB.
