SHO Continental
Moderator
I finally got to prepping the subframe that will go into my ATX.. it needs a new one after a little.. well.. lets not get into that.
anyways.. this frame came off a '94 ATX SHO, also had the motor trans and all front suspension still attached.
Today I went up to my dad's where it's 'stored' and we pulled the engine, trans, struts/knuckles, PS rack, and LCAs off.. then we used a pressure washer to get all the grease off. Then we started wire-brushing the rust that was hiding under the grease.
Took a little while.. but it got done!
And I tried my best to clean all the rust from the subframe bushing mounts..
We used some rustoleum hammer something something paint.. can't remember at the moment and all the paint is at my dad's... it's meant to be sprayed over rust, and it has a texture to it.
Here's the frame after paint.
Should be in the car in a week or two..
