14,000 miles ago I performed a 4 wheel brake job with Powerslot (sport) rotors and EBC redstuff pads. Right from the start I noticed a "ribbed" feeling from what I thought was the front rotors, that was much more pronounced the harder I braked. I double checked everything, including the direction of the slots on the rotors. Everything looked fine, so I figured it might go away after some miles. No such luck. So, last week I had the OEM rotors turned and put them back on. No other changes, I even re-used the same front pads.
Smooth as silk. No idea why these rotors felt so weird, but even my passengers could feel it! So, buyer beware. I am sure someone will suggest there was a flawed install or defective rotors, but the Powerslots look pretty normal after removal and inspection and all I changed were the front rotors to correct the problem.
Thought I would inform others just in case.
