blownatx95
Minnesho on an alternate user name
I've done a search but I thought I would put out my list of codes and hopefully some of the SHO gurus can help me on where to start. the light was not on all the time, but would come on after driving. there was no certain time it would come on, sometimes after 50 feet of driving sometimes after 10 miles. anyways the light became steady upon start up sometime back and I just now had the time to address the situation. I am getting power to the main relay(on the rad support near the airbox), I tested the relay and it is operating correctly. I even replaced it with a known good one to be sure. I checked all the power and grounds on the ABS controller and they are good. I did not check the pump relay which is located near the controller and pump, but I have anotherone in the shed I was going to swap and see if it makes a difference. Anyways here is my list of codes I retreived and see if you can help me on where to start taking into consideration what I've already done.
17 reference voltage failure (i beleive this was set when I removed the relay
to test it)
31 LH front sensor
35 LH front sensor
36 RH front sensor
37 RH rear sensor
38 LH rear sensor
41 LH front sensor signal missing
55 LH front sensor long term signal failure
61 Short circuit to ground in HCU FLS harness
61 Short to ground pedal sensor switch
75 Intermitant loss of signal under 25mph LH front sensor
All help is greatly appreciated!! thanks!
to test it)
31 LH front sensor
35 LH front sensor
36 RH front sensor
37 RH rear sensor
38 LH rear sensor
