RedDemonSHO
ok i have a 93 SHO ATX that was swapped to a MTX, it still has a ATX computer, harness, ccrm. has been running good for a few years now, a couple days its started acting up cutting in and out check engine light flashing (have vid) then just died!!! looked at it and found that #3 **** fuse (EEC) blew so changed it it lasted 5 miles and was still cutting out and flashing light. changed fuse again and nothing!! so did some digging, found that the fuel pump wasnt kicking on, did the fuel pump prob test and the pump kicked on. tried to pull codes and got nothing not no codes NOTHING like it would even flash or start fan!!! so i swapped computer still not able to pull codes. took the CCRM out and apart found there was a burn break in the board so resoldered it and still NOTHING!! Its a "J" CCRM and the part that was burnt went to a relay wire numbers 8 (yellow wire) 24 (red wire) and 4 (blue with black strip) , Anyone help or ideas will HELP!!!! thanks
