My 89 sho build thread
Connecticut
I'm starting this thread to document my build on my 89. Owned the car for a year, 100k on it ATM. Here's a list of what I've already done to the car:
~ 60k
~ 155 lph fuel pump
~ Reinforced front/rear mounts
~ Gen 2 starter
~ Plus hood (we'll see when I get around to painting it xD)
~ Tpr rear endlinks/bushings
~ A/C delete
~ Goodrich stainless brake hoses
~ Battery relocated to the trunk
~ Yellow fogs
Mods on the shelf waiting to be installed:
~ BBB/painted/ported intake
~ 20.6 front swaybar/bushings
~ Gen 2 directional slicers
~ Sunroof delete (lexan)
~ Nitrous kit
~ 3.2 swap
Some pics:
Irish Pride
Irish Inside
MusicCityUSA
High flow Ypipe and rod shifter need to be on your list. The Ypipe is the 1st upgrade that I recommend and will really let that Yamaha breathe.
-Chad
Connecticut
-Chad
Thanks Chad. I forgot to add it in there. Had one on my other sho and it really made it run, definitely going on this one. Should be getting a good deal on rod shifter/flywheel/clutch/alsfb next week... rod shifter feels so much better than the cable.. this is my first gen 1 and I immediately noticed the difference.
Connecticut
Update:
Went on a road trip to pick up some goodies last week... yesterday I pulled out the headliner (was trying to save it but... it dissipated in my hands) and freed my Alsfb from the subframe they were attached to. Took a lot of heat and in the end I got em with a two foot pipe wrench... they're a bit mangled but will work just fine. Also here's some valve cover painting pics (old oil filler cap is busted)
Connecticut
Finished porting the heads the other night, and finally got the intake reassembled todayw the BBBs. Pretty happy with how to color turned out it was what I was going for. Next week I'm going to install my alsfbs and rod shifter.. also ordered some new tires..
Connecticut
Okay its been awhile but my cut moogs/sensa tracs are in for the front.. I went with 1.5 coils cut. Now just have to drive it to settle them. Im not worried about the back for now. My sunroof delete is almost complete. Not sure if I'll make my track day by June.
Connecticut
Well I haven't been too busy with the car, but I managed to fix the rust on the dogleg. This was the only spot of rust on the whole car after I pulled the skirts a year ago, so im happy its done. Im no bodyman, but it turned out okay, good enough for a racecar!
Connecticut
Updates... new rear calipers/pads and resurfaced my rotors. Also got the car stickered up. Next on my radar is my rod shifter I've been refreshing so pics of that install to come soon. Track night in America at Limerock next week!
