Multiple sensor faults given in slushy conditions
widetracker57
Kalamazoo, mi
Driving my 2014 Sho in slushy conditions has resulted (twice) getting multiple fault messages for: ABS, Traction Control, Cruise Control, etc. It will last for 5-15 mins, then clear. Guessing there must be a connector somewhere that needs attention? Any ideas out here? Thanks in advance!
2014 SHO, Diamond Black (non perf ed.), 50k miles
usually a wheel speed sensor or tone ring. if you have ACC, worth checking that as well.
Lostneye
NY
I would bet on a wheel sensor first, but ... get the codes read, that will tell you.
This, I just had a wheel season replaced under warranty and it only showed up when it snowed. Once it melted/dried up the lights went off and it functioned normally. Luckily I was able to get it to the dealer while it was on and they verified, by the time they ordered the part and got it the light was off again.
widetracker57
Kalamazoo, mi
Thanks to all. So apparently it's not a common issue with these vehicles. Will get the code(s) identified and report back on findings.
Think Spring and happy motoring!
shootinirons
