redwraith94
My Sho has 240k original miles on her, and the trans had lost 1st, now it doesn't have 2nd, or 4th. The original owner did lots of burnouts with stock diff pins, but has a spare trans from another sho with ~90k miles on her.
I need to swap the trans out, and am going to purchase a ceramic tob from shonut, other than that I know I need to work on the diff pins for the replacement trans. I want to replace the clutch as well, and found a Beck / Arnley on rockauto for 102?!
http://www.rockauto.com/catalog/x,carcode,1138508,parttype,1993
http://info.rockauto.com/BeckArnley/Detail.html?0616185.jpg
1. Are these better than stock, or less than / equivalent?
2. What other prevantative maintenance should be done to, or items replaced on the spare trans? i want this car to last a loooonng time (in terms of the powertrain, all the other ford parts on her can't be helped
3. I had heard that a way to upgrade the diff pins was by using hardened shoulder bolts. Would anyone like to comment on that?
TIA :thankyou:
)3. I had heard that a way to upgrade the diff pins was by using hardened shoulder bolts. Would anyone like to comment on that?
TIA :thankyou:
