MTX transmission noise and jerking
Jherico Earl
Title basically says what the problem is. Drove home from work today and the transmission started wining, not going into gear, and then started semi-locking up and chattering/jerking. Did I destroy the trans or could this be something with the diff? Any questions, please do ask. Thanks in advance guys
sperold
Last to Know
Could be the differential pin scraping on the differential casting / housing. It breaks through the case eventually.
Or, it could be the throw out bearing has broken through the clutch pressure plate fingers, or at least half of them, and that is a noisy situation and has some of the symptoms you are talking about.
Check your transmission fluid as a start.
it could just be out of fluid...
AREA 91
PA SHO SHOP
Area 91
It does sound like a diff pin failure. I would not move the vehicle one more foot, or you risk punching a hole through the case.
