Motor swap help/won't start after 2013 EB into 2011 EB
Rmowery1
St Louis
I bought a 3.5EB out of a 2013 MKS. Swapped into 2011. Changed cam and crank sensors. Also the plug coils and the flywheel. Put it all back together. It will only crank. But no start. Any help would be a blessing. Thanks.
That is why it wont start.
Did you change any computer parts?
jmr061
WI
Any update?
Rmowery1
St Louis
Spent multiple hours checking fuses,relays,wire harness plugs and grounds today. Still cranks but no fire.
P1602 on a Ford vehicle means that the pcm has disabled the vehicle (it won't start) due to a communication error. You have to get rid of that code and its cause or the engine will never start.
That is why I asked if you changed any computer parts anywhere. So, the possibilities include: wiring harness / connector issues, a bad pcm or other required can-bus item gone bad (note that "gone bad" can include simply having lost their correct programing identifier for the car). Unfortunately, it is not something to diagnose over the internet. It is very likely you will need it towed to the dealer and have them put their scan tool on it to identify which component is the culprit.
RAYJAY
WHO ME ?
UNION DALE PA
QUICK QUESTION would forscan help with finding the problem
Rmowery1
St Louis
I feel good about my decision then. I'm having it towed to the dealer today to have them take a look. I'll post an update when I get one. Thanks for everyone's help.
As noted on another thread, it could be a crankshaft tone ring issue. I would check that that is not what is happening here.
Rmowery1
St Louis
Dealer still can't get car to start. The only thing that didn't get changed is the crankshaft trigger ring/tone ring. They have not been able to get an answer if that is the problem or not. What's your thoughts?
Have you looked at the original thread cited on that issue? Those look very different in tooth count. Try a websearch on that topic and see what pops.
dan.delargy
