motor mount locations?
jspec23
Lowell, Ma
Can someone please tell me where the motor mounts are located? I know I have a bad one, because my engine jumps around. I tested it by setting the brake and slowly moving forward. The engine moves like 3 inches. My flex pipe also bends enough for exhaust to leak out and make my car louder. So I need to know what to look for. I know where the tranny mount is, but the other two i'm not sure, do the have anything to do with those dampers on either side of the engine? Any help would be appreciated.
yamahaSHO
E85 whore
Arkansas
First off, I would say to look under your car, they are pretty obvious. The front mount is on towards the front of the motor in the front of the engine bay. The rear mount is in the same location at the rear of the engine bay.
There is a dampner connected to the front mount. The two visable dampners are not connected to the mounts and should be fine.
I take it you have an aftermarket exhaust? If so, fix the motor mounts then tighten the exhaust, possibly using hi-temp sealant.
SHO--ripper
928 Euro
winsted,CT
They are on the passenger side of the car. Look under the car. On the passenger side front is the mount that is most likely broken.
