Moror Mounts/Transmission Mount
Johnny_Eye
Kansas City
Motor Mounts/Transmission Mount
My mechanic friend is in the middle of some work on my SHO. He dropped the subframe and discovered I need motor mounts and a transmission mount. They are all shot. Any advice on where I can pick something up fast? I'm in Kansas City. I thought about just heading to AutoZone and seeing if they have anything in stock. Ford dealership probably charges an arm & a leg, eh? Also, any advice on what particular part(s) I should be looking for?
Thanks all.
Rudman
North Carolina
Last I checked they do not stock the SHO mounts at Auto Zone, CarQuest, etc. The dealer will have them, but they cost you - and wont last. The SHO SHOP has reinforced mounts that have additional supports welded to the mount for a stronger unit - that will last.
operdot
USA
most of us rebuild them or buy reinforced mounts, shonutperformance should stock them, also shobros.
Johnny_Eye
Kansas City
How many motor mounts are there on the 3.0L engine? On Ford websites, I'm seeing a front left, front right, and rear mount...for a total of 3. Is that correct?
Thanks again.
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
There are two motor mounts, front and rear, and one trans. mount.
Is this for an ATX (auto) or MTX (stick) SHO? Can i assume MTX, since you said 3.0?
crystizel
