somedude_001
along with the never ending issues my vehicle speed sensor is having on my car. I have replaced the sensor, the wires from the sensor to the PCM, the PCM, and I rewrote all of the stock tranny settings in the tweecer and I still have the same issue with the speed sensor not working. The transmission is still in limp mode and will only shift a 3K unless you shift it manually... enought about that for now.
My main problem right now is datalogging. in the past I would open up calcon and payload what I want to see. Usually this would be front and rear bank O2, rpm, and VSS. In the past it has worked with some sucess. acasionally the VSS would drop to 0 or to a abartrary number and then I would get the tranny symptoms I have now but it has always been so intermiten that I was never able to trace the problem. Well now the transmission symptoms are constant. Only this time I cannot datalog anything at all. I tried a bunch of different combonations of things to payload but almost everything is tied to throttle position which I really don't understand. everything that shows up in calcon is garbage. If I change the combonation of items to datalog the numbers are all different but still random. There has to be something stupid that I am missing but I really don't know that is going on here and I am ready to pull my hair out.
if anyone can help I would be more than happy to talk over the phone if you prefer.
edit: I tried to attach a copy of the ccf file but it says it exceds the forum limits by 43k
