Moonroof
Jase21
DC
My moonroof has stopped working an it is cracked open, how much would be to get it fixed?
Jase21
DC
Dead Moonroof Motor
All I know is when I press the button nothing happens. I think the motor died.
jelloslug
Digital
Greenville, SC
The relay is located inside the dash, behind and to the right of the glove box on a mount bolted to the top of the blower motor housing. The relay is a sliver cube with (for no apparent reason) a BMW logo stamped on the side.
sperold
Last to Know
The early SHOs have a place where you can manually crank the sliding portion, kind of what you see sticking out of a door when the manual lever has been taken off the window regualator. If you have a Gen 1, that will buy you some time.
Jase21
DC
I don't hear anything at all when I press the button. I have a 92 MTX. Is it possible to see pictures of the relay and the sliding portion?
jelloslug
Digital
Greenville, SC
Just fold your glove box all the way open and you will see it up and to the right.
EL SHO
Taco Manager
Monterrey, Mexico
or you can take the glove box off altogether, it's simple. just three screws in the lower part and it comes off.
I bet is the relay. I changed the relay on mine and even with a new one sometimes works, sometimes not.
Do you guys know if the relay has to be bolted to make a ground connection and work properly?
