TankII
As I'm on my way into work, the SHO will miss after running steady-state for 10 to 15 minutes. Ambient temperature makes NO difference.
Full throttle before-hand, stop-and-go, on-off - no problem.
Run steady-state for a while, and it starts to miss. Get off highway and nurse it through a couple of stop-lights, and it will be fine until I get on and start cruising. Rarely dies completely, but it comes close
Replaced (since 2004/20,000 miles ago):
Engine (2004) - Complete makeover w/ CPS, water pump, sensors, etc. Ran fine at Lime-Rock in 95+ degree heat.
Fuel pump (2006) - Now has a higher volume pump than before. Have autocrossed with no issues since.
Catalystic Converters in 2008
DIS was replaced in 2000, at around 160,000 miles.
Only issues other than this:
P/S leak I can't pin down.
Oil leak on Crank Sensor seal (only one I didn't replace)
I've put very few miles on it since 2004, as you can see, as it was rusting badly. I've replaced a bunch of panels these last two months, and drove it to work today. Started to miss at it's usual spot, but once I got into stop and go traffic, it was fine.
Maf?
TankII
Maf?
TankII
