I had two misfires, yes that's right, TWO! back in August. Two coil packs were replaced, and now I am less than 2 months later I have another misfire. Only I'm pretty sure it's TWO again. On tuesday I noticed a slight vibration on the steering wheel and gas pedal. The engine warning light has been on since god knows when, so i reset the battery but every time it comes on it throws like 7 or 8 codes at me. On thursday I take it out to drive and it's totally *****, shaking like mad at 2-4k revs and has a very rough idle. I'm 99% positive it's another misfire and 50% positive that their are two. I would assume that it's the same ones, because I swear to god i will go ape if i find out I've had 4 coil packs go bad in 2 months (unless of course something else is causing the misfire)
In addition to the occasional blinking light from the SES, I also get a brake light come on whenever i accelerate between 5 and 20mph.
Just below 120k miles. Anyone got any ideas what could be causing TWO to go bad at the same time, and what might cause them to go bad again, or another two to go bad?
