Meth tank
Boosted Sho
Ok I was tired of the tiny 3 qt tank for my methanol. And I'm really to cheap to order one for 60+ bucks. So I just took the fitting off the snow tank and the sensor. So I drilled the holes same as I did on the snow tank when I installed it and just screwed the fitting into the bottom of this tank. Did the sensor and put some ties to the organizer holes drilled for the fitting and sensor wires in the organizer. All wires have been soldered and shrink wrapped with connectors.
light behind the tank and I can see my level. Put goop on the bottom fitting just so I know it's glued in.
