SHOOFF508
Out of Retirement (again)
So i believe i finally located the cause of my temp gauge issue, the main ground that goes to the negative battery terminal, then to th fender, then to a plug/harness that if unplugged the car wont run, i found it melted/melting.
i can the car for 1 minute and found both that and the main negative cable to be HOT AS ****.
tomorow at work im gonna toss the midtronics at her and check out that alternator cuz i think somethings cooking.
any suggestions on the problem or maybe im going down the right track ?
