I remember for sure it's falling edge but I will have to check my laptop when I'm near it again for the degrees it at.
I really need to go through this and re write it all as this is too sloppy and not explained how it should be.
As for a update the car runs like a champ on megasquirt. Need to get it to the Dyno and tune the spark for top power. I am curious to see how close my timing is. Feels pretty close but Dyno tells all.
I have it running fully sequential and currently have the Chrysler coil on plugs on the car even tho I got a set of lsx truck coils
kinda went back and forth until I figure out how I want to mount the ls coils.
In case you are wondering the ls truck coils are as far as I know the strongest spark you will get for any coil on plug.
I recently installed 6 egt probes . One per cylinder and was playing with tuning each cylinder individually. Also got a idea how well the intake setup with snakes flows.
It's not like you would think with the back 2 cylinders not getting enough air. Actually does seem to get a pretty darn close to even flow through the intake.
If I recall the only weird issue with the stock intake is the second the butterflies open the transition period seems to have a flow imbalance and I want to when I have more time play with a completely stock intake with horns to see how they work Compared to my intake that's ported to the moon and bbbs with bigger throttle body.
My guess is the horns work to scavenge the air out of the plenums. Example being look at where the shorts and longs meet inside the surge tanks. The inlet port is flush so when the longs are pulling air and the shorts switch over the air flow is redirected to the shorts which has a second to starting changing direction and velocity.
I think with the horns it pulls it from a different spot and has a better chance of the air moving in a more desirable manner.
Basic idea I'm getting at it a set of shorty fatter horns would help a modified intake flow better.
This is just a thought for now and need to play with it more to get the answers.
But anyways that aside the car runs well and I need to spend more time setting up more features like launch and flat shifting etc. I do have a video when i had the tune off a little but I disconnected the maf and dis module to show I'm running solely off megasquirt
