MerkXRTurbo
Between over half a year out of work, and time spent playing with other toys, I have been away from my Merkur/SHO project for a bit. I've refocused and I'm back at it again, and acquiring my T56 was probably the biggest single financial hurdle and I am now over it. After all, it's a heck of a lot easier to spend $200 10x than it is to spend $2000 once!
Anyway, onto what you all have been waiting for: information and pics! I chose a '98-'02 Camaro/Firebird T56 for several reasons. The F-Body shifter location is very good for the Merkur, and there are some GREAT clutch options. The '94-'97 F-Body T56 can be had cheaper, but with a pull style clutch and less clutch options to boot I believe the end cost would be the same or higher with a lot more headache.
My first problem was that the T56 input shaft sticks about 1" beyond the bellhousing. For the SHO engine, I need to bring it back approximately 1" so that it's about flush with the mounting surface of the bellhousing. This is a good thing in many ways, as I need some room to take account for the thickness of the bellhousing adapter (I would have preferred more like 3/8" to 1/2", but no biggy). So my initial thought was to build my adapter out of 1" plate, although after pricing out material I decided to go another route. I made a 1/2" spacer between the bellhousing and the transmission, and then I will use a 1/2" transmission adapter.
The bellhousing is located and aligned to the transmission by two dowel pins, which were much too short to be of any use after the spacer was installed, so longer ones were required.
The old:
The new:
A little longer than they need to be, but there shouldn't be any interference with anything. If there is, I can always trim them.
I made the spacer out of 1/2" wide flat bar and tubing for the bolts. I cut and bent the flat bar into shape and welded it all together. I then made sure it was flat using my bench top belt sander. If it's not perfectly flat that's okay, that's one of the nice things about the bellhousing being located by the dowel pins. It's a VERY tight fit and cannot be skewed even a thousandth. Here it is after primer and paint:
Bellhousing installed:
From Inside:
Excess length of the dowel pin (as you can see I need longer bolts):
After doing much research I was able to determine that the portion of the T56 input shaft that goes inside the pilot bearing is only .001" larger than the 2.3 Ford, and the SHO crank accepts the 2.3 pilot bearing as if it were factory equipment! The pilot bearing may end up being the only OEM item on the car... hey, is there a racing class that only requires a stock pilot bearing?
2.3 Pilot bearing on the T56 input shaft:
2.3 Pilot bearing against the SHO crank. With a bit of force (but no more than typical for such) it would press in beautifully:
Next thing I have to do is build a transmission adapter and figure out a method of aligning the bellhousing so that the input shaft is within .005" of being perfectly centered in the crank.
The old:
The new:
From Inside:
