Manifold stud
TRSCobra
Washington
One of my manifold studs has the threads rusted off where the nut tightens down, so I took it out, but can't find a replacement. I'd get the stainless set from Shonut, but I only need one.
Where can I buy just one stud?
stockblue95mtx
stockblue95mtx
St. Marys, OH
Napa has these in card stock packages of 2 for $3-4. It will say Ford and it is an M10 x 1.5 thread. Length is 2 inches or so, not sure exactly.
stockblue95mtx
SHOtimer
#2910
Santa Clarita, Ca
IMHO, you should get the stainless steel package from SHOnut, because if one rusted through the others are on their way. I just installed them on my SHO and they are a good quality product. But, if not that Napa package works or you could go to Ford and just buy one.
Doug
TRSCobra
Washington
Doug
I would, but the others are fine. Most people would probably re-use the one I deemed bad, but I usually get paranoid about those things, so I pulled it, thinking it would be a really easy find. Maybe next time i'll get that SHOnut package, but for now "If it aint broke..."
AREA 91
PA SHO SHOP
Area 91
The studs are also available in the "Help" line. They are longer than stock, and come with brass nuts. :thumb:
TRSCobra
Washington
I went to Advance, Autozone, Carquest, Napa, and the ford dealer. None of them had one that would work. There was no M10x1.50 studs in the HELP! line either. So I just bought the SHOnut set.
AREA 91
PA SHO SHOP
Area 91
I do my best to support the SHO NUT as well. I'll post the part # for the HELP studs.
Mr Anonymous
Tire Wall
Good choice! :thumb:
I hear that just those studs alone keep about 50% of the Canadian SHO contingent employed! :naughty:
