In the midst of swapping out my Y-pipe to the Magnaflow 23355 part and had some questions and observations:
My question is - why is the distance from the rear ****** to the end of the pipe so short? Mine measures only 3/16 of an inch at one point, compared to the factory Y-pipe that is just over half an inch long. This appears to be important as the donut gasket has a half inch or so axial length. In addition, the ****** is skewed about 10 degrees with respect to the square cut end of the pipe. A call to Mangnaflow's tech line (Chris) got me "we designed this to be an OEM replacement" and, when pressed, that the CAD drawing they had showed this dimension as 1/4 inch (****** to pipe end - after I told them mine was only 3/16). I don't see how the donut gasket will be properly supported. Can any others comment on this?
Other observations - 1.) the merge was flooded with 3M Weld Through coating or similar. A large handfull of paper towels and some B12 Chemtool took care of that. 2.) On mine, the forward pipe at the merge is inserted considerably farther into the merge, so that it partially blocks the rear bank pipe. Not the greatest for performance . . . have to see if my Dremel or die grinder will get in there. 3.) important to anyone - where the O2 bungs are "plunged in" and welded there was quite a bit of ripped metal shavings that I carefully wiggled and broke off. In the exhaust stream it would certainly have come off and either blocked the cat a little or been sucked back into the engine on a downshift. 4.) The O2 sensor bungs themselves stuck MUCH further in (like 3/4 inch) than on the factory part. The effect on flow could be significant.
I guess you get what you pay for. Need to figure out what to do with the mating ****** on the factory intermediate pipe, it is corroeded through as is the ****** for it.
Comments welcome - also, are people using the Felpro donut gasket or the Ford on these? My new Ford part appears to have a too tight fit on the OD - zak
as for the gasket, i picked up mine from Lordco and they had the right number
