MAF and ECU compatibility
Cocoa,Florida
i recently purchased a PRO-M maf that is tuned for a 92 SHO,and im running it in my 90 with the B9B1. will this conflict with the tuning or are the MAF calibrations the same with all the ECU's? and if so what ECU does the 92 run an X2J?
Phoenix
SHOHOLIC
QC , Canada
92 = first year of the X2J
I really doupt there's any significant changes in all the ECUs for the MAF calibrations.
Axianator
I am a banana!
Roanoke, TX
Although it received several different part numbers throughout it's lifetime, the corporate 55mm MAF that was used on all '89-'95 V6 SHOs always retained the same MAF transfer. If your Pro-M MAF was a drop-in replacement for the factory MAF, then you'll be fine.
Cocoa,Florida
thank you sir!:salute:
AREA 91
PA SHO SHOP
Area 91
Glad to see you cruzin the board again Adam! How's the family?:salute:
Axianator
I am a banana!
Roanoke, TX
Thanks! They're doing well. My 2 1/2-year-old daughter, while incredibly smart, thinks that she's "Ms. Thang", and her 14-month-old brother is starting to test his own boundaries while mimicing everything she does.
Never a dull moment! ;)
