Congrats on the impending maintenace!
My intake cleaning is goin down this evening and hopefully finish up tomorrow morning.
I bought a perfect babybottle brush yesterday @ Wal-Mart for $2. It will clean 5" into the lower manifold. I'm not sure how much that will leave uncleaned.
I have a few thoughts 4 U:
I have a spark plug air fitting that I use for compression checks and leakdown tests. I am thinking about determining which cylinders are on the compression stroke as it sits after I dissassemble the intake. I'm probably going to clean those cylinders first. The cylinder getting the scrub will have 130psi piped to it to make sure the valves are sealed well & no solvent drips past. Then after careful double checking to make sure nothings gonna get in the motor when I move the car I'll put it in 5th and push till the remaining cylinders are on the compression stroke. (will need repetition to catch all cylinders on compression)
I bought a venturi type vacuum pump ($10 @ Harbor Freight) and built an ultra-high suction(30 inches of mercury) "shop vac" using vacuum lines and a coffee can as the crap trap.
I've already got way more time into prep than is sensible, but my vacuum would suck blood right out of skin
(unverified!)
I am going to install a clear fuel filter in the PCV line as learned on this forum. This should lessen future crud. (we'll know in 20K when 3rd 60K is due)
I am NOT one to endorse being any where near the contents of 12 cans of Berrymans in one lifetime.
My removeable parts are gonna soak or I'm gonna bite the bullet and pay for hot tanking.
If you ever plan on having kids without birth defects keep carb/brake/berrymans cleaner exposure to a bare minimum. Wear gloves, eye protection and plenty of VENTILATION!
Hope my rambling helps any, good luck!
One more thing: Be careful to to test the cleaner on the upper intakes anodized coating. I wasn't concerned since I'm gonna run through the sandpaper grits from say 120 to 600 then put the full polish on mine while its apart
Ok I lied - two more things: I won't have a helper available to lift the intake for me, but since the hoods off I'm gonna us my cheapie tie down straps hanging from the rafters hooked to the intake to slowly lift, look, disconnect, and repeat.
<small>[ March 17, 2003, 02:35 PM: Message edited by: Don likes SHO ]</small>
