Drivers side headlight was looking ******** dim so I checked last night and it's putting out 11.7 volts. Motor off battery output was 12.45 or so and checking voltage drop between plug positive and battery positive gave about 0.64 volts. Does this mean it's NOT a ground issue? It's worth noting that I currently have a small length of 18 awg wire (4" or so) attached at each ground point on either side of headlights (near hood strut attachment) that are not attached to anything on the free end. These are eventually going to be soldered to the plugs on the wiring harness I haven't yet installed (have 1 or 2 more solder joints left to make).
So here's my question for that: Is there any variance in relays as to what input voltage is needed to open them? IE, would the 11.7 volts be plenty to trigger most relays on the market? If the low voltage OEM plug was on passenger side, it would be moot, but I made the harness so that it would attach to the driver's side oem plug, which is the one that's low. I honestly haven't gone out and stretched out the harness to see if I could reverse it, I just dont want the relays anywhere near the exhaust manifold.
Thanks
Thanks
