Lost all instrument lights HELP!
Skeetin870
Tulsa Ok
Recently all my instrument lights (tach speedo fuel temp) have gone bad.
I checked all the fuses and then i went and replaced the actual bulbs. Nothing happened. Night driving doesnt really work because obviuosly i dont know how fast im going please help. All the other lights work.(climate,radio ect) PLEASE HELP.
EDIT The dimmer is set as high as it will go and all my other lights controlled by the dimmer are bright.
dpsutphin
Fort Worth Texas
I assume you have checked the fuse as well. If so, check your installation of the switch. On some of these cars, there is a piece of metal behind the switch that can cause it to short out and not work if it touches it. There is also the chance that you just got a bad switch.
ohfosho
ontario SHOwner
ontario, canada
i noticed it mentioned (in the manual), that there are like 3 different fuses that say something about gauge cluster lights...check those again
