Loss of Low End Power!
91 Plus
Well-Known Member
Monroe,Michigan
I painted my intake on my car.I noticed today that I dont have any low end power.I cant even chirp my tires from a dead stop.Anyone know where to start?
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
there's your problem right there. :D Seriously, our your secondaries working? Did you leave one of their vacuum lines disconnected? Did you reconnect the Fuel Pressure Regulator vacuum line? How did your intake gaskets look? Did you re-check the torque on all the mainifold bolts? There's a few places to start!
naval-avi8or
Chesapeake, VA
They all keep telling you to check the secondaries. Easy way is to start the car and see if they close. They will be open prior to the vacuum pressure building. If they don't close check the 8 connection pionts for the secondaries. If all are connected check for any other vacuum hoses from other systems that are not connected as they may keep the car from building vacuum. As your doing this check for leaking and pinched hoses (its happened before).
91 Plus
Well-Known Member
Monroe,Michigan
SHO SPD:
???? did you repaint it?
No I did not repaint it..I just realized I couldnt get any noise from a dead stop.I realized it up at your place but I thought it was cause I just got brand new tires.But,its definatley have no power at low end.
crystizel
