Marccus
I am installing a new CPS, water pump, and lower radiator hose. The system is completely empty of coolant.
I torqued all bots on the WP and I am getting a loss of 1.25 psi over 5 minutes.
I tightened all the hoses, especially the lower one, and rechecked the bolts on the WP.
I'm still losing pressure at about the same rate.
Is this rate a problem?
Should the system only be pressure tested when it is full of coolant and the loss of pressure in an air filled system is to be expected?
