loctite cam fix with TSB
jzautotech
nj
here is the procedure. I see a lot of discussion without real info. the site wouldnt let attach the bullitin as pdf. basically it says to apply loctite 294 which is a special product for this repair, to the cams after heating them with a heat gun and the left side of the vehicle raised off the ground. this product flows when heated and dries with serious strength. may be a good option for people without the funds to send out for welding or have no access or nohow to use a welder. I will try to host the pdf somewhere else or if someone knows how i could put it up let me know. If you'd like a copy of it shoot me a message
follow the link for the tech info on loctite 294. looks like some good ish!
https://tds.us.henkel.com//NA/UT/HNAUTTDS.nsf/web/CD64A4E5A766C9BE882571870000D627/$File/294-EN.pdf
AREA 91
PA SHO SHOP
Area 91
Well, my head hurts after reading that.
It's hard to believe that's english.:nut:
jzautotech
nj
Adding Loctite 294 to the camshafts may extend the life of the bond between the camshaft gear and the tube. This procedure is appropriate for engines not experiencing upper engine valve train noise. If such noise is present, replacement of a camshaft may be required.
NOTE: Loctite 294 MUST BE OBTAINED LOCALLY THROUGH AN INDUSTRIAL SUPPLY SOURCE, OR USE THE LOCTITE WEBSITE: WWW.LOCTITE.COM GO TO THE "COUNTRY" "DISTRIBUTOR LOCATOR" USE PRODUCT NUMBER "27935" AND ENTER THE ZIP OR POSTAL CODE.
Remove valve covers as per Workshop Manual Section 03-01C. Measure the gap on all four camshafts as per Figure 1. If the gap is wider than 0.047" (1.19mm) on any camshaft, only the out of specification camshaft must be replaced as per the camshaft replacement procedure in the Workshop Manual. Proceed with this repair on all other camshafts.
Place lint free towels under the camshaft sprocket area and clean between the camshaft and sprocket using brake parts cleaner or equivalent to remove any engine oil, (see Figure 2). Blow the area clean and dry with shop air. Perform this procedure two times for each camshaft and perform on all four camshafts. Remove the towels from under the camshaft sprockets. Hand rotate the engine one complete crankshaft revolution until the cams have turned 180 degrees and perform Step "1a" again to clean the opposite side of camshaft sprocket area on all four camshafts.
CAUTION: FAILURE TO CLEAN THE CAM TUBE/SPROCKET AREA WILL RESULT IN POOR ADHESION OF THE LOCTITE MATERIAL.
Raise the left (drivers) side of the vehicle approximately 18" off the ground to insure secure *********** of Loctite 294 through the camshaft tube and sprocket.
Use a heat gun and apply heat to each camshaft gear for 30 seconds, place towels under the sprocket and over the chains, then immediately apply Loctite 294 to each camshaft per Figure 3. Perform this same procedure on the other three (3) camshafts. Remove the towels from under the sprockets. Rotate the crankshaft one revolution, place towels under the sprockets, and apply Loctite again to all four (4) camshafts to saturate the opposite side. This will require approximately 0.34 oz (10ml) of the Loctite 294 to complete application to the four (4) camshafts.
CAUTION: IT IS VERY IMPORTANT THAT NONE OF THE LOCTITE DRIPS OR WICKS ON TO THE CHAINS. IT IS POSSIBLE FOR THE LOCTITE TO "LOCK" THE CHAIN LINKS, RENDERING THE CHAIN INOPERABLE. ANY LOCTITE SPILLED ON THE CHAIN SHOULD BE IMMEDIATELY WIPED OFF AND THE AREA CLEANED WITH BRAKE PARTS CLEANER. CHAINS SHOULD BE CHECKED AND CLEANED AS NECESSARY WITHIN 10 MINUTES OF THE APPLICATION OF THE LOCTITE.
Clean any excess Loctite from each camshaft and sprocket using a shop towel, remove any towels previously placed under the camshafts, and reassemble the engine per Workshop Manual Section 03-01C.
Change oil and filter.
NOTE: THE LOCTITE 294 WILL BEGIN TO HARDEN WITHIN 10 MINUTES OF APPLICATION. FULL STRENGTH IS ACHIEVED IN 24 HOURS. FOR THIS REASON AND MAXIMUM EFFECTIVENESS, THE VEHICLE SHOULD BE PUSHED OUTSIDE AND LET SIT FOR 24 HOURS BEFORE STARTING THE ENGINE.
nothingtoseehere
Yeah, we know. That information has been out for a long time. It has also failed.
Also, Loctite 294 is not a special product made for Camshafts.
Siman
Location Location
I wouldn’t do this as a permanent fix; it’s like hoping that super glue will hold a brick. But if it would by me time till I got it to NESHO or an experienced cam welder, I would.
There's no way that you would want to mess with that twice. It's a real PITA.
screnshaw400
Michigan
You might as well have someone tig the cams if you are going to tear it all the way down to locktite the cams. I believe ford came out with this "fix" initially, and it has been proven not to be as good as welding the cams.
k mier
dexter mo
If it was only gong to be a temporary repair, what about the chance of not being able to remove all the loctite before welding? It's possible heat from welding could draw that into the weld along with any oil that still remaines, making for a weak, hollow weld.
If it was my ride and I wanted to save it...trailer. (BTDT)
SHOCH
Tommy Boy
near SHOcago
I'd like to suggest using that loctite on your keyboard to alieve my headache, then have it welded once and correct by nesho
Mr Anonymous
Tire Wall
Somewhere there are pix of Kirk and I "fixing" cams with everything from adhesive spray to zip ties, with things like ketchup and duct tape in between.
An even easier way to apply the Loctite is to just squirt a bunch in the oil filler and then run the engine at 6900 RPM for about 20 minutes.
SuperHO
Mental Patient
St. Joe, MI
hmmm...maybe i'll give that a shot on the 98. by the way, chris...we missed you, snookums.
