Location of Backup Lamp Switch
I would definitely discount for less than the full service. The majority of the labor on the timing belt change is the removal of the accessory belt and pulleys, crankshaft damper and timing belt covers. This same labor is need to access the CPS, front main seal and the water pump. The UDPs, however, are less of an effort without the removal of the timing covers, crank damper and timing belt.
Here is a cut-and-paste of the list I keep for the 60K parts.
Top End Engine Work
1. Valve gap check/adjustment, SHO NUT Performance, $3.48/shim
2. Spark plugs, Motorcraft AGSP-32PP, FordPartsNetwork.com, $3.99 ea., Discount Auto Parts, $3.49 ea.
3. Spark plug wires, 3.0L: Motorcraft WR-4033, FordPartsNetwork.com, $83.99+s&h, 3.2L: Motorcraft WRE-4081, FordPartsNetwork.com, $134.99+s&h
4. Valve cover & plug well seals, Fel-Pro VS50378R, O’Reilly, $91.99+tax, AutoZone, $72+tax
5. Intake manifold gasket set, Fel-Pro MS94831, RockAuto.com, $46+s&h
6. Thermostat, Motorcraft RT-1112, Ford, $12+tax
Front End Engine Work
1. Timing belt, Gates T248, RockAuto.com, $32.82+s&h
2. Accessory belt(s), 3.0L: Gates K040500, Gates K060445, RockAuto.com, $10.48+s&h, $11.41+s&h, 3.2L: Gates K060854, RockAuto.com, $20.58+s&h
3. Water Pump, 3.0L: A1 Cardone 57-1373, O’Reilly, $61.45+tax, 3.2L: A1 Cardone 57-1458, O’Reilly, $67.99+tax
4. Crankshaft Position Sensor, Wells SU242, AutoZone, $42.99+tax, Borg-Warner CSS54, O’Reilly, $56.29+tax
5. Front main oil seal, National 710220, O’Reilly, $7.99+tax
6. Fuel filter, Motorcraft FG800A, O'Reilly, $8.69+tax
Scott
dan.delargy
