Bigsho2
- Joined
- Feb 22, 2018
- Messages
- 13
- Reaction score
- 10
Ok, so here we go, I have looked through the forums as much as a week permits and so I'm asking for some advice on a couple of issues. the car is a 1991 SHO with automatic temp control first and for many of you the easiest I have an air bag light that flashes 4 over and over and over, my research shows this to be safing sensor, which I'm guessing is the rear airbag sensor located on the firewall some clarification/affirmation here would be very helpful. The second issue is a little more perplexing, when I bought the car it had a brand new ATC control unit (dash controls) installed (could be bad), the car was blowing at full speed only no matter the setting, turning it off would then change it to blow full speed from the defroster. 2 days after ownership everything went to normal and everything worked correctly. But then it would periodically make quick bursts of high speed notably each time I would touch the brakes, use the turn signals, headlights turned on or I accelerate hard. This lasts for just seconds and it then returns to the requested speeds. I believe this could be a headlight switch or dimmer switch if not a wire. (reading tonight is saw something regarding vacuum lines?) the braking /acceleration leads me here. and lastly the coolant light comes on occasionally, the car was 1/2 quart low when purchased topped off correctly and then days later the light came on although it had not previously came on when it was low. I shut off the car to check it and it was good and restarting it the light went out and stayed out. until this afternoon it came back on and went out on its own. I predict a possible grounding issue if anyone has a list of grounds to check I would be happy to clean them up
I am not an electrical engineer, but am comfortable with circuits. Lastly if you are still reading this thank-you, I vow to research until I pass out several days straight before bothering anyone with my issues.
