StealBlueSho
How much boost are you 2010-2012 LMS guys seeing sustained in 3rd gear with with the 4+X tune?
Sent from my Nexus 6P using Tapatalk
Bruce is spot on. There may be times that your TQ MGT system will command 15 to MAYBE 16, but for the most part logic will calculate a 14-14.9 max.
Large displacement+positive displacement. You gotta use that AWD against those guys lol.
Like we have noted several times, more boost will always equate to more heat. The EB platform as a whole already has a PHD in heat creation. We choose to keep boost relatively low and use engineering to make power.
To monitor on your own, doing so mechanically is going to be more accurate than VIA the OBD route. I will save the entire forum the dissertation on logging, but if you have to see needles and gauges that is the best way without selling a kidney for insane monitoring equipment like we have.
