livernois 4x?
Livernois Motorsports
SHOForumSponsor
Sponsoring Vendor
Dearborn Heights, MI
Turn the traction control off if you are trying to do ANY spirited driving. Wheel hop will cause the ECU to **** power.
And yes that labeling on your tuner is correct.
Big Mike 74
thank u and is it the tune that changes the way the car sounds as i let off the gas or just because of increased boost causing the squeak of air noise when i let off its the wastegate most likely??
poffffd
