flakedawg said:
ok thanks ill check and see what all he is changing before i drop it off. What all does he need to change if he said the compressor was done.
Wow, this thread went from try to see what was wrong to just taking it to a mechanic.
Personally, I would just go buy the $25 can of freon and guages, then check the pressure. This of course would be after checking the electrical connection.
Hate to tell you, but if you walk up and ask a mechanic what's wrong with your car and you say you think it's something that is expensive, 99.9% of the times they will say it is just to make you feel that you knew what it was and charge you up the ****!
Before you drop it off, and if you refuse to go check the pressure, take it to another shop and just tell them you want the pressure checked. This shouldn't cost much at all.
Best bet is to find out if the little things are what went wrong, because you will get stiffed at any shop if you don't know anything about the car. Sorry if it sounds harsh, but I know many mechanics and a customer like you is what they want coming into the shop everyday! Sad, but true...
Edit: If he is going to change out
any parts, you better request to have your old parts back. Also, usually when the compressor is replaced, they will replace most of your other components like the accumulator and lines. The last thing you want is just to replace the compressor, if it really went out, because all of the small particals from the old compressor will contaminate the rest of the system, which will eventually take a crap on you again, shortly.
