aaron240
Hello ecoboost community,
As this tittle states I am in the process of retrofitting the MKS adaptive suspension to my 2015 SHO. Please see the parts list below of the factory Motorcraft parts used to make this swap possible. Physically, the electronically adjustable dampeners or "Magnaride" as most are familiar with, can bolt right up to the SHO. This modification once complete will allow the driver adjust the softness or stiffness of the suspension with the simple push of a button from the driver seat. This should be applicable to SHO's with HR springs as well, so if a softer ride is desired at the lower HR ride height, simply push a button to accommodate. Lincoln states that their electronic dampeners used in the factory suspension can provide up to a 15% softer ride than stock and up to a 20% stiffer ride than stock, this gives an approximately 35% swing of adjustable ride softness/stiffness control.
To my knowledge, this swap has not been done in the 10+ years the SHO has been out. If anyone has done this swap please advise and weigh in as I do have some additional questions to complete the swap. These questions include to the Lincoln MKS Suspension Control Module's input voltage/current fed from the ECM or BCM, and the resulting output dampener current values which are used to control factory ride settings.
