Mr95Gl
Mr Tire Iron
As usual, I haven't the slightest clue on where to begin with my newest problem. I start the car up, idles high for abit, then the lights start to dim in and out. Also, the fuel pump starts whining like crazy, and my temperature gauge begins to skyrocket. Once the lights stop dimming, the temp gauge shoots back down, and the fuel pump stops screaming. During this occurence, I can hear a noise (sounds bearing related) around the belt area. Could this be my alternator going south? If so, would it cause these other symptoms? I believe the last time I drove the car, the battery light came on for less then a second.
While I'm here. . . . my heater core took a dump. To bypass it, all I need to do is run one hose connecting the metal lines from the firewall to each other? I'm guessing the same goes for the lines that run to the motor? Thanks in advance. I think I need to start prepping the 3.2, because with my luck lately, I'll be needing it shortly. To bad I realllllly love this car. . . .
*Edit* Car in question is a 94 MTX, if that matters.
