thecrew2999
3.2 MTX SHO
Dylan said:I don't how different the gen3s are from 1&2 but, I pulled all my carpeting out of the gen3 and their is NO WAY that it weighs 120lbs. or even anything close to it. Maybe 25lbs at the most.
I pulled the dash out but had help, so I don't know if was 150lbs. But it was alot closer to 150 than the carpet is to 120lbs. I of course put the dash back in (since i do kinda need it).
A fwe odd ball things that can be pulled out, all speakers and RCU. carpet material inside the doors, all venting pieces, heater core, AC unit, everything to do with the AC unit under the hood (maybe keep compres to keep same belt), airbags.
By removing the AC piece that looks like a radiator and sits in front of the Rad shoud remove maybe 5lbs (really light) but it "should" help cool engine down ALOT better.
Basically anything you don't use or need can go. you can see the heatercore is gone and the AC thing is still their. But it's gone now.
In fact the littel cable you see lying near the gas pedal is even gone. That does something with the button on the floor shifter. It just means I don't have to touch the brake when pushing the button in ( but I always will anyways)
dont know if they are different or i was just tired that night but i swear that carpet was heavy and the dash wasent no treat itself, basicly i did the compairision guessing around my g/fs weight so its rough estimate.
they says the mtx weighs 90 lbs and im telling you that thing is light as **** no way its 90 but who knows till you break out the scale haha
The comfort quality doesent go away if you keep just the seats right?
